Ciaran 4 Posted May 4, 2008 Report Share Posted May 4, 2008 My car has been making a squeaking noise i thought it was the bearing in the tensioner. I took of the serpentine belt off and there seems to be play on the pulley that is turned by the flat side of the belt. Should i take it out and fix it or just fit a new pump? Link to post Share on other sites
Matt W 4 Posted May 5, 2008 Report Share Posted May 5, 2008 Flat side?My belt is ribbed both sides (for hers and his pleasure )Don't think the bearing in the water pump can be replaced got to replace the whole pump but its an engine out job to get at the water pump Link to post Share on other sites
ingham 5 Posted May 5, 2008 Report Share Posted May 5, 2008 engine out job to get at the water pump...no... you can jack up engine just Link to post Share on other sites
VR6_Absy 0 Posted May 5, 2008 Report Share Posted May 5, 2008 it's not an engine job .... you can undo engine mount bolt and jack the engine up enough to get pump out. Be careful tho that you don't over jack Link to post Share on other sites
gav_113 0 Posted May 5, 2008 Report Share Posted May 5, 2008 as above.. mine was a bastard on my old engine to get out..!! rusted in the block..lol Link to post Share on other sites
hopefulVR6owner 0 Posted May 5, 2008 Report Share Posted May 5, 2008 YEAH AS ABOVE I HAD TO DO MINE 2 WEEKS AGO. WHEN MINE STARTED TO GO I HEARD A RATTLING NOISE BUT THOUGHT IT WAS JUST THE CHAINS STARTING TO RATTLE COS IT CLEARED AFTER A WHILE BUT AFTER A WEEK OF RATTLING IT FINALLY GAVE WAY SO YOU DONT WANT TO LEAVE IT TOO LONG. TOOK 45 MINS INCLUDING BLEEDING COOLANT SYSTEM. YOU HAVE TO REPLACE THE WHOLE PUMP ONLY COSTS £25 - £35. OBVIOUSLY RENEW ANTI FREEZE AND IF YOUR FEELING RICH JUST ASWELL REPLACE THE BELT. Link to post Share on other sites
Ciaran 4 Posted May 5, 2008 Author Report Share Posted May 5, 2008 The belt was done quite recently but may just replace it for peace of mind.Sorry but engine out my arse it is just a matter of raising the block a foot or so and haping the driveshafts re-seat ok. New pump it is seeing as it's cheap. How much is a VAG one? Link to post Share on other sites
Phat VR6 3 Posted May 5, 2008 Report Share Posted May 5, 2008 You can fit the mk4 pump which has metal impellers instead of plactic for about the same price Link to post Share on other sites
Ciaran 4 Posted May 5, 2008 Author Report Share Posted May 5, 2008 You can fit the mk4 pump which has metal impellers instead of plactic for about the same priceok may try that Link to post Share on other sites
Phat VR6 3 Posted May 5, 2008 Report Share Posted May 5, 2008 http://www.mjmautohaus.com/catalog/index.php?cPath=2_6_15_42_112_1365 Link to post Share on other sites
hopefulVR6owner 0 Posted May 7, 2008 Report Share Posted May 7, 2008 must just have been luck but when i got mine it had metal impellers. someone said to me that it would have plastic impellers but it didnt and as it fitted straight in i didnt think nothing more of it. Link to post Share on other sites
frannybigballs 0 Posted May 10, 2008 Report Share Posted May 10, 2008 mine has decided to let all the water out through the pump as im putting it in. not good. i'll do it myself but im not happy with the driveshafts bit, truth be told i didnt really consider it. do you have to guide them back in or will they be ok if its jacked just enough?sorry if it seems ive hi-jacked, dont see the point in starting a new thread when there is already enough info here Link to post Share on other sites
