cadguy77 0 Posted May 12, 2008 Report Share Posted May 12, 2008 Hi Guys, need some helpMy speedo needle has all of a sudden started acting crazy. No rhyhm or reason, just happened with nothing to tell me why.when ignition is on the needle just spasms, it flicks round doing 360's, then holds pointing down after going past 160mph (on the clock, not my speed). Then back to 0, and repeat.And after a run, with the ignition off andd key out it will swing round past 160mph, and hold pointing down.It's just plain wierd.Anyone experienced this?Any pointers towards the cause would be greatly appreciatedCheers guysAs Link to post Share on other sites
ingham 5 Posted May 12, 2008 Report Share Posted May 12, 2008 my clocks did funny turn when i blew a fuse for fag lighter,is fine with new fuse Link to post Share on other sites
jezmoz 0 Posted May 12, 2008 Report Share Posted May 12, 2008 speed sensor ? Link to post Share on other sites
cadguy77 0 Posted May 14, 2008 Author Report Share Posted May 14, 2008 It's very weird to say the least.I'm trying to upload a vid to show you guys.Speed sensor sounds the most logical reason, but then it's behaviour doesn't act to that logic.Doing a constant speed, if I accelerate the needle shoots round past 160mph, if i decelerate foot off throttle the needle shoots round to 0mph, and if i apply very very very slight throttle the needle flicks around like a crazed mofo.I'll upload vid asap Link to post Share on other sites
cadguy77 0 Posted May 14, 2008 Author Report Share Posted May 14, 2008 right heres the vid.As described, when it shoots round past 160mph i'm applying over 2% throttle, when it shoots back to 0mph i'm off throttle decelerating, and when it wiggling all over thew place i'm apply less then 2% throttle Link to post Share on other sites
slim5878 1 Posted May 14, 2008 Report Share Posted May 14, 2008 have you put a new stereo or had stereo as there is a speed pulse wire behind the stereo and if that touches an earth it will do sum weird stuff Link to post Share on other sites
Phat VR6 3 Posted May 14, 2008 Report Share Posted May 14, 2008 Its just playing lol... Id never seen it before but first thing id do is check the connection on the clocks and the fuse board. Then try new clocks from ebay sell again if doesnt solve. Check wiring down the speed sencer. then try a speed sencer Link to post Share on other sites
Eat this 2 Posted May 14, 2008 Report Share Posted May 14, 2008 i think the speed sensor is the easiest thing to check as its easy to get to i think id be thinking earth or sensor rather than clocks Link to post Share on other sites
SankysVR6 1 Posted May 15, 2008 Report Share Posted May 15, 2008 What about trying that trick you do with the MAF display, as I'm sure you can set that to display the speed. And if that works I think you could eliminate the speed sensor. Link to post Share on other sites
cadguy77 0 Posted May 16, 2008 Author Report Share Posted May 16, 2008 Right, all sorted (for now).Took the speed sensor connector off, problem still present.Took clocks out, tried another set, finePlugged my clocks back in, lost all cluster fuctions.Took earth strap off battery, reconnected, all is well again with the worldhappy days Link to post Share on other sites
