xyber 1 Posted May 30, 2008 Report Share Posted May 30, 2008 Had a feeling the MAF was shot and possibly the coolant temp sensor, so borrowed a pro code reader from a garage to scan it and afterwards it was a bit hesitant to start, anyone had or heard of this before?cheers Link to post Share on other sites
Charged VR 0 Posted May 30, 2008 Report Share Posted May 30, 2008 Do you know if the learnt values were erased for the throttle valve? Link to post Share on other sites
xyber 1 Posted May 30, 2008 Author Report Share Posted May 30, 2008 dont think so, just the 2 faults that popped up, it was fine once started, just wondered why it would do it Link to post Share on other sites
Charged VR 0 Posted May 30, 2008 Report Share Posted May 30, 2008 The ECU learns the postion of the throttle valve which controls the idle speed on OBD2, If this was erased it can take a few minutes for the ecu to learn its position again. Do you have a K&N Filter? Link to post Share on other sites
xyber 1 Posted May 30, 2008 Author Report Share Posted May 30, 2008 I get you, Im stage one charged Link to post Share on other sites
Charged VR 0 Posted May 30, 2008 Report Share Posted May 30, 2008 What Charger are you running? Link to post Share on other sites
xyber 1 Posted May 30, 2008 Author Report Share Posted May 30, 2008 Vortech V9f Link to post Share on other sites
Charged VR 0 Posted May 30, 2008 Report Share Posted May 30, 2008 I went down the Rotrex route, Whats the vortech like? Link to post Share on other sites
xyber 1 Posted May 30, 2008 Author Report Share Posted May 30, 2008 solid bit of kit, alot bigger than the Rotex but the price was right through a GB, really glad I did it, stage one just gives you a hefty kick in the arse at 3750rpm is onwards which is fine, but now I fancy it kicking in lower down the revs so am gonna try a schrick inlet with it.Still toying with the idea of going to stage 2 or 3 but not sure if its worth it as I seem to spend most of my time sat in bloody traffic Link to post Share on other sites
vw_golf_vr6 0 Posted May 30, 2008 Report Share Posted May 30, 2008 edit: mod please remove, replied in wrong topic Link to post Share on other sites
