kniterider 0 Posted June 1, 2008 Report Share Posted June 1, 2008 front left wheel bearing has developed a slight rumble since lowering the car last week, slight bit if play so was going to nip it up and see if it quietens down, but i couldnt, my 30mm impact socket that i used on my mk2 gtis' etc dont fit, it seems as though its a big multipoint socted needed?? any ideas what size please, glad i didnt buy a bearing yesterday and think about doin it today!! Link to post Share on other sites
philbatesvr6 0 Posted June 1, 2008 Report Share Posted June 1, 2008 they are a casset bearing on the front not a tapered one so you wont be able nip it up jus replace it Link to post Share on other sites
Phat VR6 3 Posted June 1, 2008 Report Share Posted June 1, 2008 they are a casset bearing on the front not a tapered one so you wont be able nip it up jus replace it Is true but if that center bolt is loose there will be play in it Link to post Share on other sites
Charged VR 0 Posted June 1, 2008 Report Share Posted June 1, 2008 The Nut is a 12 sided 30mm, Halfords normaly have these sockets, Try giving it a nip, wont do no harm, is nothing rubbing? how low did you go? Link to post Share on other sites
kniterider 0 Posted June 1, 2008 Author Report Share Posted June 1, 2008 deffo nothing rubbing, have double checked that, i will try giving it a nip up 1st as there is a teeny bit of play, will probably still be noisey after, ony £17 for a new bearing from eurocarparts and will use the press at work thanks for the info on the socket, i might have a 12 point rather than my 6 poin one at work too so ill check... Link to post Share on other sites
