Norrisvr6 0 Posted June 2, 2008 Report Share Posted June 2, 2008 Hi, recently purchased vr6 golf obd2 yday and having issues already with it... The window doesnt seem to want to go up all the time... When u hit the auto button to put window up it goes up to bout an inch from top then decides to go back down. How can I fix this??? as its really annoying... Link to post Share on other sites
jezmoz 0 Posted June 2, 2008 Report Share Posted June 2, 2008 I'd say you need a new window regulator and or motor http://www.gtishrine.com/windowreg.phphttp://www.pocketrocket.ca/mk3_window_regulator.html Link to post Share on other sites
xyber 1 Posted June 2, 2008 Report Share Posted June 2, 2008 mine does it aswell, I think its the finger trap safety as everything is fine on it? I keep meaning to take the rubber out and give it and the window a really good clean, I found rubbing a little birthday cake candle in the rubber runner helps it slide better and stops it playing up Link to post Share on other sites
Norrisvr6 0 Posted June 2, 2008 Author Report Share Posted June 2, 2008 Its working fine just seems to be the finger trap safety thing nothing to do with motor but whats regulator do? Link to post Share on other sites
AndyW 0 Posted June 7, 2008 Report Share Posted June 7, 2008 Having the same problem, boutgh a new motor and still a problem. Now bought new window running window rubber from the Main stealer (£70) hoping this works. Link to post Share on other sites
