I recently noticed my zorst was blowing near the cat. When up on the ramps I see there's a capped nut that's rusted off a small inspection / monitoring port at the rear end of the cat.
Can I get a replacement easily? Is this port actually used in MOT's or other inspections, because if not should I just weld it closed?
I heard you can just weld it up. if you do find a bolt that fits in the hole let me know. i just bunged it with some exhaust repair paste. cacked myself when i first heard it as i though the lambda sensor had fallen out of it LOL but i know a few vr's that the same thing happened to. dont even know what the hole is there for in the first place.
