H13VYY 0 Posted June 5, 2008 Report Share Posted June 5, 2008 hi. i need to roll my rear arches to fit my 9j rims. I want the arches rolled without damaging the paintwork. But every bodywork garage iv been to so far have said that it is impossible to roll them without damaging the paintwork and also that if they heat up the paint..it will bubble up. Wheelmania in tamworth have advised me to get a angle grinder and to do it myself..but i don't want to risk doing it myself. Does anybody know any place that could sort my arches out? I know it's better to do the full job and sort the paint out to, as the paint may crack later down the line..but i dont mind that right now. Thanks Link to post Share on other sites
SankysVR6 1 Posted June 6, 2008 Report Share Posted June 6, 2008 Archenemy, are meant to be pretty good and they come out to you.You could also try styledyanmix (sp)I guess no one can guarantee it won't damage the paint, its just risk you will have to take. But what ever you do don't cut the rear arches, as they are double skinned and are for strengthening the rear. Link to post Share on other sites
slim5878 1 Posted June 6, 2008 Report Share Posted June 6, 2008 angle grinder then seal the arches after Link to post Share on other sites
jaysVR6 2 Posted June 6, 2008 Report Share Posted June 6, 2008 An angle grinder is the worst possible way to loose your arch lip as the arch is double skin'd and if you grind the edge off it you risk distorting the arch. Come on guys is this the Ford owners club site? Do things by half and you'll always end up with half the job.The only way to do it is to be prepared for paintwork and have them folded back completely against the arch and sealed. You'll end up with inner arches just like a beemer and they'll be strong. Link to post Share on other sites
xyber 1 Posted June 6, 2008 Report Share Posted June 6, 2008 Have a word with a specialist alloy wheel dealer, a local one to me rents out the proper tool that bolts to the hub to fold it back properly, you will need a paint touch up generally but some people have been lucky with one of those hand held steam cleaners or heat gun to heat the arch as they go, which can make the paint just flexi enough if you work very slowly, but as VW stuff is hard paint it probably wont work, but worth ago anywaythen once done go mad with the waxoyl and itll be spot onThe angle grinder route is only worth it if you are going to completly weld along the grind line to fully water tight it, which is normally done if the car is getting a full spray job and MASSIVE wheels where even a small lip is too muchcheck this out and http://vwcaddyforum.com/showthread.php?t=1864 and Link to post Share on other sites
H13VYY 0 Posted June 6, 2008 Author Report Share Posted June 6, 2008 what is that arch rolling tool called? Link to post Share on other sites
xyber 1 Posted June 6, 2008 Report Share Posted June 6, 2008 these guys are mobile http://www.archenemy.co.uk/contact.htmor buy your own tool http://www.frost.co.uk/item_detail.asp?productID=9108&frostProductName=Wheel%20Arch%20Roller Link to post Share on other sites
Phat VR6 3 Posted June 6, 2008 Report Share Posted June 6, 2008 I donno but the proper ones cost £260 :S Im going to make one soon for my wheel spacers. Got a old brake disc for the hub and a spare jack. Best thing i can find for the wheel is off a skate board but its abit to small and hard I think..... Anyone got any good ideas of somthink to use for the wheel??? Link to post Share on other sites
xyber 1 Posted June 6, 2008 Report Share Posted June 6, 2008 poly bush of some sort? or a trolley caster? Link to post Share on other sites
xyber 1 Posted June 6, 2008 Report Share Posted June 6, 2008 http://cgi.ebay.co.uk/WHEEL-ARCH-FENDER-PULLER-LIP-ROLLING-FOLDING-TOOL_W0QQitemZ380033087885QQihZ025QQcategoryZ30923QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247orThats the place near me that rents the tool out, dont know if they would do it through the post but worth asking http://www.wheelpower.biz/ Link to post Share on other sites
Phat VR6 3 Posted June 6, 2008 Report Share Posted June 6, 2008 £150s not bad.. Know afew people round hear that want it done so could neary get my money back. Wonder if they would sell just the wheel lol Link to post Share on other sites
xyber 1 Posted June 6, 2008 Report Share Posted June 6, 2008 all chip in for it, then its there to rent to peeps when needed hahaha Link to post Share on other sites
matty.vrt 120 Posted June 7, 2008 Report Share Posted June 7, 2008 ive got a skateboard wheel thets proper soft and about 32mm diamiter any good. Link to post Share on other sites
Phat VR6 3 Posted June 13, 2008 Report Share Posted June 13, 2008 abit small I think but thanks anyway. think about 2" wide and diamiter of about 70mm would be perfix. Im still on the look out Link to post Share on other sites
