bulldog - both big and small light models had single lamp grilles. the 4 lamp was always on optional extra, except on the campaign.....
may have to chop and change between them..
richie.. she is not a bad one mate. i'm not gonna put the d90's on it - just was bored and did a chop for a laff really.
may have to find some 15" le castellets as they look about the same - ish..
  • 3 weeks later...
  • Replies 71
  • 4 weeks later...
have been trying not to spend any money on the mk1, seeing as i still owe sam the money for it....... but..........
some red stripe seats came up on ebay, they looked pretty good so i bid and won them.. wooo!
when i picked them up they looked pretty good and after a damn good clean - they are!!
old one out, new one cleaned and ready..
two new front ones .
old and new rears, check the fade around the seatbelt on the bottom right of the old one!!!! can't have moved for years!! :-p
all fitted and nice and red and not ripped to shreds!
most pleased :D
  • 2 months later...
spoiler is gone!!
but it had rust underneath!! :@
and loads of holes drilled in it to hold on the spoiler too
still, with the badges on it looks loads better!! :)
so, in celebration, i went to the beach!!
but i have found another tailgate which is absolutely rust free. this is half prepped now and will be sprayed and on soon enough!!
also have brand new badges, front plate holder, 1983 style dealer plates reprinted,... roll on next summer..
  • 3 months later...
blimey! haven't updated this for a while..
have had a busy winter on the mk1 whilst it has been hiding away in the garage. figured i'd take the opportunity (mot and tax have run out, won't be used again till april :-( ) to strip, clean and repaint most of the bits under the bonnet, so i took the rad, battery, lights, grille, bumper, airbox, water hoses and most of the vac hoses out. moved the wiring loom for lights, starter horns etc out of the way for maximum room....
this is why i am doing it...
:angry: :omg yuck!
has obviously had a leak for quite a while....hmm this is gonna take some cleaning..... time to break out the degreaser....
so far i have done the chassis legs, front panel and have started on the top of the gearbox and the front of the block..
this could take a while?!!
started to make some good progress!
still quite a way to go yet, and a few bits to get painted also. but it's definately showing signs of improvement!!! :D
i'm not taking the engine or box out, or really going to town on it - it's just getting cleaned and a few rusty black tinware pieces painted. my budget for the whole bay is £100, so it's all gotta be as cheap as poss - so far i'm on £10 for the degreaser and about a fiver on bolts, washers, clips i have ordered for the rebuild!!!!!!!!!!!
deageased, dried, prepped and painted the water pipe, water hose to head joiners, water pump and the horn bracket (still hanging to dry on the key rack... ooops..)
all the wax and oil is now gone from the chassis legs and bottom of the front panel, needs polishing up still though..
more to come tomorrow hopefully.........
not too bad so far..
painted the servo and master cyl, and the fuel filter bracket and clamp, and the ecu holder and the metering head too. made a start on cleaning up the wiring looms and clips after that also.
tomorrow i think i will be cleaning the bits of bulkhead i can get to and as much of the lower inner wings as i can too (down to where the wishbones mount to). then will paint the clutch arm, gearbox mount and coil bracket...
(and i said i wasn't gonna go overboard!! doh!)
degreased the bulkhead and chassis legs, and the rack and mounts and as much down there as i could get to... then dried and polished all the paint work i had degreased . . . . . what a bastard that was.. i have cuts, but i won. eventually.
did the front panel too so that is all ready.
then, painted the gearbox mount, and the block.
cleaned up all the head too which has come out really well . . . .
mmm shiny chassis legs...
alternator and oil cooler next,.... :omg
just waiting for payday now to get bits back from the powder coaters the i can start to rebuild.. :yey wooooooooop.
all the bits came back today from the powder coaters, so now i have a nice stack of new or refurbed bits to go back on :D
at the powder coaters i had done -
rocker cover + strips
cambelt cover
rad surround + brackets
water pump pulley
alt pulley
alt brackets
battery clamp
front engine mount
stripped, cleaned painted and refurbed myself -
water pump
water joiners to head
metal water pipe
alt fan
coil
starter
horns and bracket
headlight backs
little ecu thingy on bulkhead bracket
gearbox mount
clutch lever
servo
master cylinder
engine block
metering head
braided fuel lines
new ready to go on at the weekend -
radiator (came with the car)
chrome water hose clips
water bottle
bolts nuts and washers for everything i have refurbed and the powder coaters did
jubilee clips
flaps and white clips on rad surround
centre section of grille
washer pipe
vacuum hose bits
also got the oil cooler all painted up and ready too . .
so all that lot has to go in here..
:D
the rebuild will start on saturday. wooo :lol:
also have wolfsburg series 1 3 spoke steering wheel and red stripe dash section to go on too.!
should look gooooooood...
can't wait for the summer to get cruising in the sun 8)
last weekend, started to finally put it all back together....
started thw weekend like this...
didn't take long to get the rocker cover on, the coil, water flanges, hoses at the back of the bay, water bottle, airbox etc all into place..
and when i got soooo cold i had to stop things looked like this....
starting to look quite tasty ... :)
still have to finish the alternator, buy and fit cambelt and tensioner, get them fitted along with water pump and belt then double check everything and tidy some wires up and we should be ready to go.. woop
so at the mo, before :-
and after :-
and, stupidly (?) whilst the mk1 is here : -
the vr is out here : -
oh well i've been out for a good hour drive tonite in the vr to blow all the cobwebs out and get it all nice and hot, since it hasn't moved for about 3 weeks.. :$
i have been lucky and landed myself a work van to go back and forth with
which is very handy in this weather, and we have finally bought sam a new motor too, so she will be cruising in the summer in this.. :) and has been driving it at every possible opportunity so far, hence i haven't used the vr in ages...
which now has mk4 lights, clear indicators, side reps, 1/2 tint rear lights and is booked in for coilovers at the weekend..
rock on!!
woop...
WOW - looks mint mate and that is one hell of a thorough job you are doing - although after looking over your vr I am not surprised :):)
he he, cheers buddy. had to be done to get it up to scratch with the rest of the car.
and the vr....
which now has mk4 lights' date=' clear indicators, side reps, 1/2 tint rear lights and is booked in for coilovers at the weekend..
and is now on the deck...... and has had momo wheel and gearstick, black front badge, aero blades, mp3 cd head unit amp and sub too..
just need some rims for it..
she likes these:-
if anybody sees some in 7.5x16 4x100 fitting please let me know!! cheers peeps! :-p
