hi all
only had my vr a couple o weeks needs a couple of bits to bring it up to scratch most inportantly near side cv joint is knackered. Problem is its stuck solid in hub tried extraction tool with about ten ton pressure to no avail anyway thinkin about replacing whole hub bearing n stub axle(if thats what you call the bit that fastens to the suspention) wondered if its the same item as the gti before i start ringin round breakers yards
