Hi all my vr has just failed its mot, one of the things it failed on is marked down as Nearside rear (load sensor valve) braking system leaking, is this also known a brake biased valve or a brake pressure regulator or brake compensating valve, just searching the net looking for prices as my local garage has told me the part is going to cost £180 :o .
Ian
Yes that would be the part in question as it changes the fluid pressure distributed to the rear brakes depending on the weight loaded in the car.
You can get one for £54 + VAT from GSF car parts.
Thanks for the reply mate, iv heard these can get stuck causing them to leek? is that right, and is there 2 of them on the car as on my sheet is says nearside sensor?.
Thanks again
Ian
