dagovernor 0 Posted July 1, 2008 Report Share Posted July 1, 2008 does anyone know where to get the M12x1.5x40 High tensile bolts required for the conversion. i am based in leeds so local would be great. have done a search and been ringing local firms but cant find the bolts. also where can you get the m12x6mm washers? might just use 3 m12x2mm washers.thanks Link to post Share on other sites
xyber 1 Posted July 1, 2008 Report Share Posted July 1, 2008 http://www.stagonset.co.uk/?gclid=CPaHgPWNn5QCFQunQwoddw7ruA Link to post Share on other sites
dagovernor 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 thanks xyber i could get the washers from there but can not use stainless steel bolts as the tensile strength is too low. they need to be at least 10.9 or higher. Link to post Share on other sites
orangecruz 0 Posted July 1, 2008 Report Share Posted July 1, 2008 i did this conversion about three months ago 6mm was too much think mine were four mm spaced and the original bolts were long enough dont know if its cos mine is late 98 or what but took same time as normal pad and disc swap great braking now there bedded in though Link to post Share on other sites
xyber 1 Posted July 1, 2008 Report Share Posted July 1, 2008 http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=1475 Link to post Share on other sites
dagovernor 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 thanks again xyber! that kit looks good but i need the parts by fri, as gonna fit them before i drive to norfolk. old pads are grinding already! Link to post Share on other sites
xyber 1 Posted July 1, 2008 Report Share Posted July 1, 2008 If you give these a ringhttp://www.1stdirectory.com/Companies/87650_Parkins_Industrial_Supplies_Ltd.htmThey seem to do everything like that, see if they'll post them to youorhttp://www.westerntowing.co.uk/acatalog/M12.htmlor http://boltmeup.com/index.php?main_page=product_info&cPath=315_127_128_138&products_id=1019orhttp://www.leytonfasteners.co.uk/hexagon-bolts.htm Link to post Share on other sites
dagovernor 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 thanks alot will give em a bell tomorrow. was looking on the net but couldnt find any sites like that. Going on a top gear style trip through Switzerland/Italy with some a3's and r32's so will be hammering the brakes so wanna make sure i get the correct bolts!! Link to post Share on other sites
OEM+ 1 Posted July 2, 2008 Report Share Posted July 2, 2008 hi, using washers to space the caliper is not a good idea as you will still get some movement on hard braking as the caliper is not sitting flat against the hub ,you are better of using a plate which i think is roughly 10mm thick i can check mine if you want. or ecs do the longer bolts an spacer plate. Link to post Share on other sites
