stealthybear 0 Posted August 5, 2008 Report Share Posted August 5, 2008 jsut been down to my local vw garage cos i have oil on my 2 front lead-ends and presumably on the plugs!! they said possible valve stem seals? (left and middle pugs) been losing power, overheated the other day( header tank boiling) and fan seems not to be coming on?? the saga continues as does the confusion? any ideas guys and also if it si valve stem seals is it vital at the mo as i am skint?>??!!! Link to post Share on other sites
thegoth 5 Posted August 5, 2008 Report Share Posted August 5, 2008 I've been running with leaky valve stem seals / guide wear for over two years. But do not show any of your other symptoms.My only symptom is a huge plume of oil smoke when I boot it after engine breaking / over run at junctions, roundabouts etc.P.s. In that time I haven't changed my plugs or even checked them for oil so can't say if that is significant. Link to post Share on other sites
stealthybear 0 Posted August 5, 2008 Author Report Share Posted August 5, 2008 cheers friend... at least i know if it is valve stem seals it aint terminal!! Link to post Share on other sites
stewvr6 0 Posted August 11, 2008 Report Share Posted August 11, 2008 valve stem seals aren't terminal just yet but they will eventually get worse. it cost me £500 to replace 3 as the head came off and went to a specialist to be skimmed. The boiling water inthe header tank sounds like the thermostat not opening correctly, thus causing the temp sender not to operate the fan. Link to post Share on other sites
