VR Problem, NEED HELP!! ASAP
I am new to this forum but i really need help.
First of all, i have owned and worked on many VW's for quite some time but this is my first VR. I took it to get inspected and it failed due to CODEs: P1544 Throttle Actuation Potentiometer Signal too High and p0121: Throttle pedal/position sensor A ciricut range performance. I did some research and it turned out to be the TPS and probaly need a new TB.
I have checked the ECU and it is an OBD2
When i looked under the hood i noticed it had an OBD 1 TB on it. Could it be possible that who ever owned it before me replaced the engine harness with and OBD1 as well as the TB? Can it be a simple fix such as replacing the engine harness again with OBD2 and TB or is there any way i can make something work with what i have?
vwmico@gmail.com
