Hi guys
Just a quick question if anyone can help me :)
How do I now if my ABS is working or not? The light doesnt come on when I turn the ignition on but I have attempted an emergency stop and the wheels dont lock up.
Bit of a noob on cars Im afraid.
Thanks for your time
Nige
yes it is supposed to turn on then turn off...
spreadz....does yr airbag light work ok (should come on then off when key is turned) if not then it may be that the light unit isnt plugged in....
if thats not the case then the light has probably blown, easiest to get a new one on fleabay, its eay enuff to change IIRC the unit just levers off with a screwdriver
there is always also the possibility that the light has been tampered with by a previous owner to mask an abs fault:(
