huseby 0 Posted August 9, 2008 Report Share Posted August 9, 2008 Hello. i was driving my 93 vr6 on the road carfully at maby 40-50 kmh then suddenly i began to like jump forward, my english is bad btw . i have this ticking sound on the engine. and spark plugg 2 and 3 seems to be just like new. i dont look like they are igniting, looks like its not getting fuel on those 2 sylinders,i have changed: sparkplugs, coilpack, entire ecu, sparkplugg wires, new injectors on sylinder 2-3The car is running so bad, it got no pulling power at all. Can any one help me think of a problem that maby can couse the problem?ty Link to post Share on other sites
ingham 5 Posted August 9, 2008 Report Share Posted August 9, 2008 time for a compression test? Link to post Share on other sites
huseby 0 Posted August 9, 2008 Author Report Share Posted August 9, 2008 kompression test :sylinder 1 : 110 psisylinder 2 : 115 psisylinder 3 : 110 psisylinder 4 : 110 psisylinder 5 : 110 psisylinder 6: 110 psihow can i test the crank sensor if its broken? Link to post Share on other sites
huseby 0 Posted August 9, 2008 Author Report Share Posted August 9, 2008 vag com test shows:00553 mass air flow sensor00281 engine speed sensor01257 idle air control valve00533 idle air control regulation00525 oxsygen sensor (g39) no signal00515 Camshaft Position Sensor (Hall Effect Sensor) -Short to B+ (G40) : Check CMP, ifOK, replace distributor.u think all the air thing maby come from kon filter? what do you guys think i need to change if u see on my vagcom test above? Link to post Share on other sites
Smuggler 0 Posted August 10, 2008 Report Share Posted August 10, 2008 Try maf first, then camshaft sensor second, but sounds like a new mass airflow sensor is needed to me. Link to post Share on other sites
huseby 0 Posted August 12, 2008 Author Report Share Posted August 12, 2008 problem fixed, it was some contact in the round engine connetor that was broken lol only that problem and i changed everything else before checking that, stupid me Link to post Share on other sites
