Hello. i was driving my 93 vr6 on the road carfully at maby 40-50 kmh then suddenly i began to like jump forward, my english is bad btw :P. i have this ticking sound on the engine. and spark plugg 2 and 3 seems to be just like new. i dont look like they are igniting, looks like its not getting fuel on those 2 sylinders,
i have changed: sparkplugs, coilpack, entire ecu, sparkplugg wires, new injectors on sylinder 2-3
The car is running so bad, it got no pulling power at all.
Can any one help me think of a problem that maby can couse the problem?
ty
vag com test shows:
00553 mass air flow sensor
00281 engine speed sensor
01257 idle air control valve
00533 idle air control regulation
00525 oxsygen sensor (g39) no signal
00515 Camshaft Position Sensor (Hall Effect Sensor) -Short to B+ (G40) : Check CMP, if
OK, replace distributor.
u think all the air thing maby come from kon filter?
what do you guys think i need to change if u see on my vagcom test above?
