amazak 3 Posted August 11, 2008 Report Share Posted August 11, 2008 Is there anyone in the london area that can roll my rear arches? The wheels are catching alot and it is starting to grate on my nerves! Alternatively is there any cheap solutions to rasing the suspension a wee bit without replacing the springs?Thanks.... Link to post Share on other sites
tubby 0 Posted August 11, 2008 Report Share Posted August 11, 2008 Dont know any place in london to get arches rolled ,but i think you can buuy spring inserts that stiffen springs and reduce amount of travel in them .Dont have a link yet ,but i`m on the case. Link to post Share on other sites
tubby 0 Posted August 11, 2008 Report Share Posted August 11, 2008 http://store.tkomotorwerks.com/prothane/prothane-universal-coil-springinserts/g-53206.aspxthe first i came across,but there are probably more out there.Hope this helps Link to post Share on other sites
amazak 3 Posted August 11, 2008 Author Report Share Posted August 11, 2008 That sounds interesting , anyone stock it in the uk? Link to post Share on other sites
amazak 3 Posted August 11, 2008 Author Report Share Posted August 11, 2008 Anone ever tried this?? .... http://forums.vwvortex.com/zerothread?id=2435165 Link to post Share on other sites
tubby 0 Posted August 11, 2008 Report Share Posted August 11, 2008 http://www.carparts-direct.co.uk/suspension_muscle_kit.cfmyou could try these too there is also a video of how to install and they are in the uk Link to post Share on other sites
slim5878 1 Posted August 11, 2008 Report Share Posted August 11, 2008 amazak speak to mj-vr6 he can cut your arches stuff the rolling crap Link to post Share on other sites
amazak 3 Posted August 11, 2008 Author Report Share Posted August 11, 2008 amazak speak to mj-vr6 he can cut your arches stuff the rolling crapWill give him a call tomorrow, but I thought rolling is better than cutting :^) What are the benefits of cutting?vr6virgin, thanks for the input pal, that does look good as well Link to post Share on other sites
spindat45 0 Posted August 11, 2008 Report Share Posted August 11, 2008 I take it you still have the TT Comps fitted mate. If it's just the rears that are catching it might not be the arches themselves. The part of the bumper that meets the top of the arch, closest to the tyre used to rub on mine when I had the TT Comps fitted. All four arches were rolled but the rears still rubbed when I had weight in the back. If you get a couple of mates to get in the back you should see exactly where I mean. Not a defiante but you might just get away with having that inner lip of the bumper removed and save yourself the hassle. Worth a try. Also depends on whether you're planning on going for wheels with a different offset in the future. Kevin Link to post Share on other sites
amazak 3 Posted August 11, 2008 Author Report Share Posted August 11, 2008 I take it you still have the TT Comps fitted mate. If it's just the rears that are catching it might not be the arches themselves. The part of the bumper that meets the top of the arch' date=' closest to the tyre used to rub on mine when I had the TT Comps fitted. All four arches were rolled but the rears still rubbed when I had weight in the back. If you get a couple of mates to get in the back you should see exactly where I mean. Not a defiante but you might just get away with having that inner lip of the bumper removed and save yourself the hassle. Worth a try. Also depends on whether you're planning on going for wheels with a different offset in the future. Kevin[/quote']Thanks for that Kevin, will look into it, howver my rear tyres are beginning to look like grated cheese lol. Link to post Share on other sites
Cowpatmatt 0 Posted August 20, 2008 Report Share Posted August 20, 2008 never cut the rear arches!! they are double skinned and are part of the structure on the mk3. Link to post Share on other sites
