steveVR6 0 Posted August 12, 2008 Report Share Posted August 12, 2008 HelloEngine is obd1Problem I have is : Happens in every gear but an exaple is, In 3rd gear at 35 mph if i push the pedel alittle more the engine dies as tho the fuel pumps turned off.Push the pedel alittle more the car carrys on drivingAt the moment I have the throttle sensor unpluged.The car runs okish splutters when cold and revs are up and down when stopped but doesn't stall.Got a new throttle sensor and still got problem.Thought I'd ask you guys first as I dont want to go to VW.Thanks. Link to post Share on other sites
Smuggler 0 Posted August 12, 2008 Report Share Posted August 12, 2008 Tried changing the fuel filter? Does it have a standard air filter, if so has it been replaced recently? Next thing would be to check fuel pressure at the rail, then injectors. Link to post Share on other sites
steveVR6 0 Posted August 12, 2008 Author Report Share Posted August 12, 2008 The fuel filters new ,It have a K&N induction kit on with anew MAF sensor. I dont know about the fuel pressure at the rail and injectors.Also I forgot to mention if i put my foot down on the gas farely quick the engine doesn't die. Link to post Share on other sites
