how do i do that?
changed the themostat housing and all the other plastic pipes/seals there including thermostat, replaced coolant but now when i switch off the engine i can hear water gargling? it sounds like it's comming from the heather matrix/throttle body pipes so suspect an air lock.
i've driven it for a few miles and it's stayed bang on 90 degrees, fan is cutting in and out lovely and the heater is working fine.
any ideas?
