Not that easy to answer. Is it new or Used??? How many BHP are you looking to get to?
If you splash the tenner and join up as a premium member you can access the FAQ sections on tuning which give you more information on the options available MAf/Maf less etc etc
Yes it will absolutely, but it all depends on the size of the pulley that it comes with. The smaller the pulley, the faster the turbine will spin at any given rpm, and thus the more boost it will make. More boost eqauls more power. A V1 should be good for 290-300 bhp at about 8psi (0,5 bar), which is realtivley safe on a standard engine. Just be aware that you can't just strap a 'charger to an engine and expect endless power without it adding extra strain on the rest of the engine. If your engine is tired, I'd at least do the chains and tensionaers before adding boost. Else, you'll be heading even more quickly for an engine rebuild. Longevity and reliability then add power!
HTH
