Tight Nuts.....
lol anyway ....
Anyone got any tips on how to remove the front hub nuts??
Im planning on changing more or less the complete front end, tie rods, ball joints, CV joints, wheel bearings, and wishbone bushes within the next week. Ive already started on the tie rods, pretty simple to get out, but next is the driveshafts, and they arent coming out!!!
anyone got any tips on how to cure tight nuts :D lol
Thanks.
lol thanks chaps, Ive got them soaking in WD40 tonight so Ill see how they are tomorrow. Got a 2ft breaker bar but might have to stick a pipe on the end of it!
How bout using a heat gun to warm up and expand the nut? anyone tried that?
Also anything else I should change while Ive got all those bits off??
lol thanks chaps' date=' Ive got them soaking in WD40 tonight so Ill see how they are tomorrow. Got a 2ft breaker bar but might have to stick a pipe on the end of it!
Not sure on yours or dubs but cars or some of them in the past have had nylocks, so you wouldn't want to heat them if they were nylocks.
lol yea your right better keep the flames away for now...!
Seen this kit from the states which has more or less evrything I need!!
http://www.mjmautohaus.com/catalog/product_info.php?cPath=2_6_15_42_151_6567&info=OEM_VAG_357412331A.ZFTR.VR6.HD_Suspension_Rebuild_Kit_with_ZF_Tie_Rod_Assemblies_Front_Heavy_Duty&products_id=2956
Is there any place in the UK that supplies sets like this??
lol just to confirm yes the standard hub nuts are nylocks so no heat for them!!
Had a good result working on the car today, managed to get the hub nuts off in the end and smacked my chin on the wing in the process! Got them off using the WD40 and big bar, and full body weight on bar method!
Got most of the old parts out ready to replace with new parts that should be coming in on tuesday! Had a look inside one of the cv joints that I took off and balls were really scratched.
so in the end, I no longer have tight nuts, just scratched balls.... (lol!)
