Mouzer23 0 Posted August 25, 2008 Report Share Posted August 25, 2008 Hey Guys,This weekend i lifted the box on my 2003 Mk4 golf V6 4 motion just to see how throaty it would sound. For a While it was driving fine and i was enjoying the sounds Until. . . . I was putting foot on a straight stretching it a bit when the car bogged down. it still drove but power was intermitent. i looked down and ECP , ESP and Engine managment lights were on Anyways got home and checked it out and the pipe to the air box had pulled off the throttle( this would explain the bogging down because of the Air flow meter being mounted on the pipe) we fitted the pipe back and power was restored.The Issue now is all these warning lights are on. If anyone knows the Reset Sequence or something to clear the Errors i would be very happy( I have tried disconnecting the battery for 3 hours which does not work)I was a bit concerned with the ESP light being on but apparently this may be cause by a brake switch issue? My top brake light is not working.Thanks guys Link to post Share on other sites
pimpcat 0 Posted August 26, 2008 Report Share Posted August 26, 2008 the faults clear them selves after a certain amount of time my esp fault went after 5 days as for the ECP light ive heard many stories of this getting broke by changing your air box as it breaks the mass air sensor which is why i wont put a kit on mine. ive had to had an air sensor changed in mine and a ECP chip after the air sensor broke! Link to post Share on other sites
Mouzer23 0 Posted August 26, 2008 Author Report Share Posted August 26, 2008 Thanks for the advice Pimp cat. Would you have any idea why the ESP light is on? also is there anyway to test if the rear wheels are running? Link to post Share on other sites
pimpcat 0 Posted August 27, 2008 Report Share Posted August 27, 2008 esp light can come on for many different thingsas soon as ur ESP light comes on ur t/c is turned offthe Esp system is linked to the many of the cars systems it cud b a long long list without a vag com that is the only way of finding out whats goin on with ur 4motion and as for the back wheels pass as the system is very complicated a vag com will again tell u that i think? Link to post Share on other sites
Mouzer23 0 Posted August 27, 2008 Author Report Share Posted August 27, 2008 Cheers! Stupid question but whats a Vag com? Link to post Share on other sites
cabrioman 6 Posted August 27, 2008 Report Share Posted August 27, 2008 its the vw well vag diag system where abouts are u ??? check the vagcom thread to see if some one near u has one sure they will help u out matey Link to post Share on other sites
Mouzer23 0 Posted August 27, 2008 Author Report Share Posted August 27, 2008 Cheers guys ill get on it Link to post Share on other sites
