Oldirtybastard 0 Posted September 13, 2008 Report Share Posted September 13, 2008 Hello guys,I have a mk3 vr6. SC if it makes any difference.Im finding that the car uses to much water. The coolant bottle will get low if i do a long journey of say 150-200 miles. Sometimes even shorter journeys Any idea of what it could be. Its done it since ive had it and its never bothered me but dont want to leave it untouched incase it gets worse.It used to have a leak from the 3 way pipe that comes from engine into the radiator but i replaced this.Im thinking Water pump or any other ideas please?T Link to post Share on other sites
Oldirtybastard 0 Posted September 13, 2008 Author Report Share Posted September 13, 2008 Just to note the car hardly uses any oil.T Link to post Share on other sites
cabrioman 6 Posted September 13, 2008 Report Share Posted September 13, 2008 get a pressure test done that should tell u if u got any external leaks .... Link to post Share on other sites
xyber 1 Posted September 13, 2008 Report Share Posted September 13, 2008 Flatten a cardboard box and park on it over night after going for a long drive, in the morn if there are any little leaks they will show on the box and give you a rough idea where to start lookingCheck the condition of all the water hoses aswell, if they are old they could have become porous which may allow water to evapourate through but would go un-noticed Link to post Share on other sites
Oldirtybastard 0 Posted September 15, 2008 Author Report Share Posted September 15, 2008 It appears to be leaking from the expansion tank as checked today and lots of coolant spillage.Any idea why it would come out from expansion tank?T Link to post Share on other sites
thegoth 5 Posted September 15, 2008 Report Share Posted September 15, 2008 what colour cap have you got. the older black ones are notorious for failing and leaking. Link to post Share on other sites
Oldirtybastard 0 Posted September 15, 2008 Author Report Share Posted September 15, 2008 Its a neauspeed chrome one, i think its blue inside.T Link to post Share on other sites
jesterwalker69 0 Posted September 15, 2008 Report Share Posted September 15, 2008 I got a new coolant tank, new BLUE cap AND new hoses and i'm still loosing coolant on long journeys! Grrrr Link to post Share on other sites
TheMainManRob 0 Posted September 15, 2008 Report Share Posted September 15, 2008 I'm also suffering from coolant loss, fitted new Samco's and checked both rads ( cabin and cooler ) for leaks but no joy. My water has gone rusty brown again even after a major flushing so I have a snneky suspicion that the previous owner has not been using the right antifreeze and has fluffed the head gasket. Its been replaced once already at 30.000 miles. Link to post Share on other sites
Oldirtybastard 0 Posted September 15, 2008 Author Report Share Posted September 15, 2008 Just wondering, could this be needing a new head gasket or even heater matrix. No problems with car heating up.T Link to post Share on other sites
parkersdub 0 Posted September 15, 2008 Report Share Posted September 15, 2008 I had this problem and it was found to be a pin prick leak from the plastic y piece pipe. I replaced tis with an aftermarket alluminium one which was £35 on ebay and it solved problem. Plastic vag part was about £50. When get chance will post a pic of the part as its hard to explain where it is Link to post Share on other sites
TheMainManRob 0 Posted September 15, 2008 Report Share Posted September 15, 2008 I think I know the bit you mean, Gruvenparts makes them. So the best bet is to get a pressure test done? Can any garage do this ( if they have the equipment ) or is it VW stealer only? Link to post Share on other sites
Oldirtybastard 0 Posted September 15, 2008 Author Report Share Posted September 15, 2008 I think most decent garages can do a pressure test. Thats probably best thing to try first. Might try a standard blue cap also.T Link to post Share on other sites
NicDale 0 Posted September 17, 2008 Report Share Posted September 17, 2008 I found i had a tiny leak from the thermostat housing which eventually got worse and worse until it started pissing coolant out. Notorious weak point on all VR's and hard to pick up. Link to post Share on other sites
Oldirtybastard 0 Posted October 2, 2008 Author Report Share Posted October 2, 2008 Noticed the car has got to much mayo under the oil cap. what does this mean. Top end rebuild?Recently doesnt seem to be running right, bit slugglish compared to usual. A bit hesitant, The Induction pipe going to the supercharger has come off twice in last 2 days also,T Link to post Share on other sites
