mpgscott 0 Posted September 17, 2008 Report Share Posted September 17, 2008 Hi All,Firstly a big thanks to xyber who has been helping me out with my problems so far.Anyway i have had this problem where the cars oil temp keeps on climbing under normal driving, have seen it go as high as 114 before i freewheeled and let it come back down,I have checked the car out with Vag-Com and no faults found i only have the freebie one off ross tech 409.1Have changed the oil and filter, the thermostat and housing to the awesome low temp thermostat, fitted a new aux water pump as the old one was knackered. Flushed the system so does not appear to be any blockage as i ran the hose through the radiator and it seemed to run freely. Have refilled the system with 3.5ltrs of G12 and water.Left the car to run up to temp with cap off the expansion bottle and then took it for a run. When i boot it i let it go upto 108 then if you let it free wheel for only a short distance the oil temp drops down quickly. Let it go back to 102 then drove at 60mph and it rose again to 104-106 so not sure why its cooling so quickly when you let it free wheel. Also when i got back to the house i let it idle and it sat at 100 and no fans running which is a first.When i stop after the work run the car is sitting around 106 and fans and axillary pump running for about 10mins.At all times the coolant has never gone above 90. I know that the oil temp is still not extremely high but its much higher than my old cars, and also i don't like how it climbs so quickly when you boot it!Anyone had any issues like this in the past any ideas what could be the cause then??Last one is that once up to temp the car is very spluttery when pulling away from junctions at low speeds. Its fine when its cold only when at temp it starts this? Car has sone 113K miles and seems to pull well.Cheers Link to post Share on other sites
mpgscott 0 Posted October 6, 2008 Author Report Share Posted October 6, 2008 Well i removed the Air Con radiator yesterday as it was appearing to block the main radiator quite a bit and also there was no gas in the aircon system. Also fitted new plugs and ht leads and new pollen filter. Car now runs a lot cooler on the oil temp and also when i stop the car the fans are not running as they were before removal. Oil never really goes above 104 now. Also with the new ht leads and plugs no splutter when i take off result.Cheers Link to post Share on other sites
