LB1984 0 Posted September 29, 2008 Report Share Posted September 29, 2008 HiSo i recently had a an ABS sensor fitted to my golf due to it showing an error - inducated by light and after a friend has a look at the sensor.However after the new sensor was fitted the ABS light was still stayin on, so i foolishly (being female) thought ooo ill have a look the lights beind the dash - dont ask my why or what i was going to do, cos i couldnt have fixed it anyway.....So i messed about a bit a curiosity got the better of, and so i took the 'thing' apart having a nosey and well.....now the airbag light is staying on.I took it to a friend who ran a diagnostic on it, he cleared the ABS fault code, but the airbag was showing nothing!!!So i must of done something to annoy it.......Only thing is,,,,, if i fiddle with the lights i can either make the AIrbag light go off, and the abs stays on - permenatly or vice versa.... but when i secure the whole thing back together - its the Airbag light what stays on.Fistly - i hope ive put this in the right sectionsecondly - have i f*cked summert up - that can or cant be fixed????Any help??????????Thanks Link to post Share on other sites
Karr-Man 0 Posted September 29, 2008 Report Share Posted September 29, 2008 assuming that u only took out the section with the abs/airbag lights in then maybe u damaged the PCB that the lights are mounted on?? touching it with bare hands might have been enough to do it. if u delved deeper than that then u better say what u did as without that were just guessing Link to post Share on other sites
LB1984 0 Posted September 30, 2008 Author Report Share Posted September 30, 2008 no i only went as far as looking at the bulbs and what they were connected too. Link to post Share on other sites
Karr-Man 0 Posted October 1, 2008 Report Share Posted October 1, 2008 if uve touched nothing else then logic would suggest that u might have damaged the pcb??u might be able to pick another abs/airbag light assembly up cheaply on ebay or from yr local breakers Link to post Share on other sites
thegoth 5 Posted October 2, 2008 Report Share Posted October 2, 2008 does the plug only plug in one way round? or might you have inverted it? Link to post Share on other sites
