retr0dreaming 0 Posted October 14, 2008 Report Share Posted October 14, 2008 Hi,ive only really noticed this problem since fitting my heated front seats,but cannot be 100% sure that is the problem.The problem is when i put car into neutral the revs drop like normal but then carry on as if to stall the car,but then pick up again then drop off and pick up again, does this 3/4 times and while doing this the lights dim.Thing is car runs perfect but when it dips below normal idle its like it wants to stall,but like i said it picks up again,any ideas??? Link to post Share on other sites
mike 6 Posted October 14, 2008 Report Share Posted October 14, 2008 i was thinkng clutch, but couild be coil pack Link to post Share on other sites
retr0dreaming 0 Posted October 14, 2008 Author Report Share Posted October 14, 2008 i was thinkng clutch' date=' but couild be coil pack[/quote']So is there a way i can test this? Clutch seems fine because it bites nice and early....... Link to post Share on other sites
mike 6 Posted October 14, 2008 Report Share Posted October 14, 2008 i just looked for cracks on mine, wipped it off and it fell aopart cus was so cracked lol, think you can take its lead out and test it that way? Link to post Share on other sites
retr0dreaming 0 Posted October 14, 2008 Author Report Share Posted October 14, 2008 i just looked for cracks on mine' date=' wipped it off and it fell aopart cus was so cracked lol, think you can take its lead out and test it that way?[/quote']Just looked at coil pack and seems fine no cracks nothing,but its strange because i have just driven round town and it didn't do it...strange...maybe its a cold thing i don't know...I will check again tomorrow and see if it still does it,thx for the help man Link to post Share on other sites
buttmrt 0 Posted October 15, 2008 Report Share Posted October 15, 2008 Check the earths are connected well. I had the same thing recently with the revs diving up and down under braking when coming to a stop. It turned out the earth cable to the gearbox had worked loose and was moving around. Also check your battery is ok. Link to post Share on other sites
gavinvr6 0 Posted October 16, 2008 Report Share Posted October 16, 2008 you dont say if its an obd1 or 2, if its an early ish obd1 with idle control valve try cleaning this out, if any electrical circuit is used this is used to increase the revs slightly to compensate, simple way is pull the fuse for the seats if you beleive this to be the cause and see if the idle settles, or just clean the isv, there is a how-to thread on here explaining exactly what to do Link to post Share on other sites
