mpgscott 0 Posted October 18, 2008 Report Share Posted October 18, 2008 Well had a problem with my oil temp always creeping up and discovered today that the issue was the water pump, mine had no fins on it so bugger all water circulating. New pump installed!Anyway last week i managed to break the crack pipe and so got another and installed it today, put everything back together and now i have a leak at the thermostat end. I have taken the thermostat housing off and checked all the seals all looks fine, Also pulled the crack pipe off and made sure there were no leaks where this goes into the thermostat housing all looks fine. Seal for the face of the thermostat against the block is ok and the other seals all fine. I have had it off about 4 times and just cant suss where the leak is. Anyone got any ideas??The thermostat housing was replaced just a couple of weeks back and all new seals, prior to installing the new crack pipe there were no leaks, could it be that the crack pipe is not fitted right into the block end anyone have any tips on how to get this into the block properly, at the moment it is not leaking at this end (block) but the car cooling system has not been to pressure yet the leak is just with me pouring in water to the header tank. Looking down to the crack pipe into the block i can still see the rubber of the o ring. Should this be right in?? I have taken it out and it needed a new o ring which i fitted, do i need to try and sand the entry for the pipe to the block??I am thinking that maybe the crack pipe is not seated correctly into the water pump end and this is somehow not connecting correctly into the thermostat housing could this be the case and i just need to try and push this crack pipe into the block? I tried to use a block of wood and a hammer but still no success?? It is doing my head in this leak as it was not here before i replaced the pipe.Cheers Link to post Share on other sites
Rustyman 0 Posted October 18, 2008 Report Share Posted October 18, 2008 Is the pump your on about located at the front of the engine just under the head in front of the Rad ? ... Just curious as mine's leaking coolant and water i tink at the pump or pipe where it enters the block... Could we have the same problem ???Let me know if u sort it ? As i was wondering the same as u if it was the seals on the pump or pipe etc.... Link to post Share on other sites
mpgscott 0 Posted October 18, 2008 Author Report Share Posted October 18, 2008 Hi Rusty,The pump i am talking about is the water pump which is driven by the belt it was totally knacked they are supposed to leak when they fail but did not. Not one fin was left on the pump all broken.The pipe i am talking about is the crack pipe which runs between the thermostat housing and the engine block beside the water pump. Link to post Share on other sites
Rustyman 0 Posted October 19, 2008 Report Share Posted October 19, 2008 Right i know which one you mean now ! ta Link to post Share on other sites
mpgscott 0 Posted October 19, 2008 Author Report Share Posted October 19, 2008 This is a pic of my buggered old water pump.I would advise anyone who has there oil temp running high to have a check of the water pump. Mine had done 114K miles and going by the water temp gauge it all looked ok only tell tale sign was that the oil temp kept on climbing upto as far as 114 degrees thats as far as i let it go. Simply let the oil temp climb then free wheel and see if the temp comes down thats what mine was like. Link to post Share on other sites
Rustyman 0 Posted October 19, 2008 Report Share Posted October 19, 2008 oh bugger... don't say that !! paranoid my pumps gonna need looking at too now !! Link to post Share on other sites
mpgscott 0 Posted October 19, 2008 Author Report Share Posted October 19, 2008 Its really easy and they only cost £20 for the pump and seal, i also replaced the belt.See this link http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?151352 it will show you how its done takes about 1Hr.Worth a look what temp is your oil running at? Also this link http://www.vwspares.co.uk/g3cooling.php is where i got my pump from. Link to post Share on other sites
craggsy 91 Posted October 19, 2008 Report Share Posted October 19, 2008 I remember someone saying a mk4 version is better Link to post Share on other sites
craggsy 91 Posted October 19, 2008 Report Share Posted October 19, 2008 Part number is same for VR and 4Mo engines Link to post Share on other sites
Phat VR6 3 Posted October 19, 2008 Report Share Posted October 19, 2008 mk4 ones come with metal blades Link to post Share on other sites
mpgscott 0 Posted October 20, 2008 Author Report Share Posted October 20, 2008 Yep the one i ordered came with the metal fins much better! Link to post Share on other sites
Rustyman 0 Posted October 21, 2008 Report Share Posted October 21, 2008 Right have i missed a trick here ? what are the part numbers for the 4 motion water pump ? (assume it will fit straight on to the VR6 OBD1 i have ?? ) and what is the part number for the Aux water pump ??? i will replace both and think i may as well got for some nice silicone hoses at same time ... Gents cost for sdaid items please ????? Anyone ???? Link to post Share on other sites
craggsy 91 Posted October 22, 2008 Report Share Posted October 22, 2008 ETKA says part numbers are same for mk3 vr6 and mk4 4mo...so its just a newer part that replaced plastic fins on pump Link to post Share on other sites
mpgscott 0 Posted October 22, 2008 Author Report Share Posted October 22, 2008 Rusty the pump i got from vag parts that i listed above is the new improved type with metal fins so its what you need.Aux water pumps are quite expensive though. Link to post Share on other sites
Rustyman 0 Posted October 25, 2008 Report Share Posted October 25, 2008 Thanks guys... i will get the parts soon after my wedding has stopped draining the cash from my pocket.. I'll have it all done before MOT in Jan Link to post Share on other sites
