gazchill 0 Posted October 20, 2008 Report Share Posted October 20, 2008 Hi, Im fitting some new discs and pads on my VR6 and have a few quesitons1) The rear calliper doesnt have any anti-sqeel shims/clips. Is this normal for a VR6 calliper ?2) Do I need to replace the calliper pins when I change the pads ? GSF said they dont do a brake pad fitting kit for he VR62) Any suggestions for front discs, can i use the later and slightly larger VR6 discs (95 onwards) on a pre 95 version ODBC-1 (If thats what its called).The car is charged so would like to uprate them a little.Thks Link to post Share on other sites
rodney 17 Posted October 20, 2008 Report Share Posted October 20, 2008 Ok so I must admit I cant remember off the top of my head for the rear antisqueel ... anyone else???If doing the rear discs as well then may be do the bearings at the same time. All accessable at the same time when you take the disc off the back. makes sense really, but not essntial! All parts are fine to refit. If it worries you then replace them. After all you have to drive it not us!GSF dont do a kit as such but you can buy the discs and pads for it all seperately. Fitting is very straight forwards just remember to take the top off your resevoir and drain a little fluid if needed. and Soak everything the night before in releasing oil (wd40) as they are always rusted in as you would expect.If you have an ODB1 chances are you are on 280mm brakes and yes the 288mm fit straight in .... again from memory.GSF do have upgraded disks etc so look at those. I got Brembos and then fast road (Padgid) pads for mine and it works well. (I am chagred as well) Lots of people go with black diamond disks, but again your choice.Dont forget if you are a premium member then you'll get discount which all helpsgood luck Link to post Share on other sites
gazchill 0 Posted October 20, 2008 Author Report Share Posted October 20, 2008 Thanks, why do i need to open the brake fluid resevoir and what bits do i soak in WD40, have already stripped it down....Thks Link to post Share on other sites
gavinvr6 0 Posted October 22, 2008 Report Share Posted October 22, 2008 the anti squel shim on a vr rear brake set up are a thin bit of card/thick paper, nothing special, they usually come glue to the back oif the pad's, well mine did when i got replacements Link to post Share on other sites
gazchill 0 Posted October 26, 2008 Author Report Share Posted October 26, 2008 I've got my discs back on, and am ready to put the calliper back together.My haynes manaul ses :-"Ensure you renew the capplier pin bolts and that they new bolts are coated with a locking compound"Does anyone do this ? I cant even see where to but them from.Thanks Link to post Share on other sites
cabrioman 6 Posted October 26, 2008 Report Share Posted October 26, 2008 if u got new pads they should have come in the box if ur using old pads they use old bolts just put a bit of lock tight on the thread Link to post Share on other sites
gazchill 0 Posted October 26, 2008 Author Report Share Posted October 26, 2008 Hmmm, Yes they are new pads (Green Stuff, purchased very GSF)No new pin bolts though Link to post Share on other sites
cabrioman 6 Posted October 26, 2008 Report Share Posted October 26, 2008 well the old bolts should be ok just put a bit of lock tight on them mate thats all i do Link to post Share on other sites
craggsy 91 Posted October 26, 2008 Report Share Posted October 26, 2008 well the old bolts should be ok just put a bit of lock tight on them mate thats all i do But you're nearly as big a bodge queen as Jim......... :-p Link to post Share on other sites
gazchill 0 Posted October 27, 2008 Author Report Share Posted October 27, 2008 Can anyone tell me where the pressure is on the Calliper. Is it on the Calliper (very difficult to remove) mounting bolts or the calliper pin bolts ? Which one should be tightened up the most ? (what is the torque for each) Link to post Share on other sites
