project rebuild and 300 plus bhp... up dated 02/08/09... last chapter ....
  • Replies 279
TSR Peformance down Somerset sell these. £599 +£139 for fitting kit. And charge £220 to fit it.
Details are on Club GTI about them' date=' they say they look good and offer a lifetime guarantee on em
mmmm interesting cheers mate :) I need more traction !!
Also at TSR they do Quaife diffs at £600....plus fitting kits etc
might have to give them a call and have a chat - but was hoping to talk to the dark destroyer Tony at the pod later this month first
well it almost back in the box will be done and dusted tomo once ive had a go in it ill tell u all about it ben and u will see it in action at the pod .
£220 to fit a diff thats a bargain that is for wot ive just had to do !!! not a diy job needed to drill out the old ring gear rivits then press them out, then torque the new bolts down then press the new bearing on ... could not hav done it wit my workshop lol
how about pre load and all that shiz? Or is it just going back in as it came out, Agree about the £220 been a very good price
managed to get a fare bit dont today ,,,
got the crank in with new King race bearings and ARP studs
6 new pistons and ARP rod bolts
clean up block and head faces
fitt ARP head studs ( be carefull when fitting these as u can get them in the wrong order lol yes i did it lol)
fitt 2mm head spacer and 2 metal head gaskets ,,,, should give mw about 8:1 comp ratio according to vince at stealth
fitt and torque down the head
and finish re building the gearbox
I give your new diff a week tops LOL only jk good luck with it
So you've used 2 metal gaskets? not split one into 2?
what happends with the gearbox? remove cups, remove selector tower, remove bolts and just split and lift apart? does anything spring out or anything else to watch out for
what happends with the gearbox? remove cups' date=' remove selector tower, remove bolts and just split and lift apart? does anything spring out or anything else to watch out for
its almost that easy but u have the selector for 5th i think it is hold both casings together bit of a pain to got out but dont it ok ... and no nothing sprung out
got some more done today was hard work thou as had a mates birthday last nite and got in about 2 or 3 i think lol
rite first things first ort out my hangover ... job done
now onto the engine... got the alternator, pas pump, idler and my new lighter pulleys on...
then the nice shinny red injector main, crank pipe, oil filter housing and oil cooler.
rear engine mount, knock sensors and crank shaft position sensor
oil pump
sump ... which i have bashed the dents out off lol
then for the lower chain
then the upper chain
chain covers
checked engine turned over all good and timing marks line up again even better... then the lovely red cam cover
light flywheel and black diamond clutch is next..
now for the gearbox, starter motor, front engine mount .... spot the mistake d`oh .....
sorted that mistake lol .... now for the coolant hoses, thermostat housing, aux water pump, coil pack, and engine wiring loom
job done and nice 2.9 vr6 low comp engine with all ARP hard wear ready to go
