Anyone got any tricks? Just gave it a quick whirl before it started raining and its pretty solid and the crappy position its in stops you getting any leverage on it, even with the proper tool! Looks like I may need some 4-poster time to make life easy :)
Yeah putting in a new one as the old one has died and giving low voltage fault on VC, suspected it was on its way for a while.
Had a feeling its probably fused itself in, using a hammer did nothing at all! Trying to scav some ramp time on sat morning down my dads work to get some decent access to it and get my fuel usage back to normal fast
I was joking about the hammer lol,,, Try it hot and cold... might be easyer after a good run when exspanded or on a cold morning.. might make it easyer,,,
Can't you double up a pair of spanners, or deep socket and braker bar.. failing that add heat
Its coming out one way or another lol Some things that can take minutes ends up 3 hours, unscrew replace lol 5 minute job
I did give the hammer a go but not much point as you have to be careful with the CAT
Spanners, you cant really get in there as they are up in the tunnel and the lambda is fitted at an angle so the spanners catch everything
The proper tool is a long socket with a handle in it but its just so seized that was useless
Ive had a cunning idea though, just need to digg out a 22mm ring spanner to sacrifice to make up a tool, just waiting for a slot on the ramps now
xyber you got a part number for that lambda sensor ' date='need one for my 1997 ,good luck with yours m8y
Ill go and get it in abit when ive warmed up, I got locked out last night, lost my key whilst on the lash, so ive been sat in a deck chair for 6 hours at sub zero temps, trying to keep warm by BBQing chicken dippers
Not a happy camper at all!! hahaha
  • 2 months later...
would the lamda cause it not to start, changed cam and crank sensor, cleaned MAF and ISV and throttle body, battery checked, but when i try starting my vr it over fuels and i think its flooding as you can smell fuel in engine bay, and if it does start plenty out the exhaust? any andvice
