slow_matt 0 Posted November 7, 2008 Report Share Posted November 7, 2008 Hello,My VR6 Highline has started missfiring below 1000rpm over the last couple of days in this tripe wet weather. Pulling away in first gear feels like it's been put into 3rd of 4th gear. Are there any common problems that I could try first as it's intermitent. I've used the search function and found a lot of problems but no real common theme.Many thanks as usualMatt Link to post Share on other sites
ip 0 Posted November 7, 2008 Report Share Posted November 7, 2008 In this order:Spark PlugsHT LeadsCoil PackNo real test except to replace items one by one and see if problem goes away I'm afraid. But the first two items aren't too pricey and both are available on ebay for not much cash.These HT leads are really good value. Cheapest I've found and seem to be very good quality. I've been using them on mine for 9 months now:http://cgi.ebay.co.uk/VW-GOLF-MK3-VR6-CORRADO-VR6-PLUG-LEAD-SET-C247_W0QQitemZ200269469611QQihZ010QQcategoryZ9889QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247ip Link to post Share on other sites
Damo 85 0 Posted November 7, 2008 Report Share Posted November 7, 2008 second that fella. had the same prob in wet weather, eventually just ended up constantly missing, turned out to be the coilpack LOL, but definately try the plugs and leads first as they're a much cheaper fix Link to post Share on other sites
slow_matt 0 Posted November 7, 2008 Author Report Share Posted November 7, 2008 Cheers,I'll keep you updated as to the fix!Just waiting for the car to be recovered as I hit a pot hole on the way home and my locking wheel nut key is missing Link to post Share on other sites
thomas2012 0 Posted November 7, 2008 Report Share Posted November 7, 2008 Just a few questions, how does the car rev up when stationary? what is throttle response like? is it worse or better when cold? when was the last time you replaced your air filter and changed your oil? and do you know what your voltage is at idle from your alternator, when cold and warm? Link to post Share on other sites
