sanchez 0 Posted November 8, 2008 Report Share Posted November 8, 2008 hey all. my car is costing me a fortune. got the starter fixed couple of weeks ago because it wasnt starting; problem solved! got in the car 2day and nothing!!!!!!!!!!!! checked voltage at battery, 12 volts. then checked power at starter 11.75 volts. surely it cant be the starter again????????????? Link to post Share on other sites
cabrioman 6 Posted November 8, 2008 Report Share Posted November 8, 2008 are u gettin voltage down the smaller signal wire to the starter then the key is on carnking??? Link to post Share on other sites
sticks 0 Posted November 8, 2008 Report Share Posted November 8, 2008 maybe bad neutral connection to the chasis, Link to post Share on other sites
DMARK 0 Posted November 8, 2008 Report Share Posted November 8, 2008 it could be the ignition starter switch. when turning the key into the crank position wobble the key up and down and it should start if thats your problem Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 tried wiggling the key. still nothing!!!! im getting the voltage when i turn the key on the small wire to the starter. wheres does the neutral connect to the chassis????? Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 the cable goes from the starter, to the gear box, to the chassis under the battery tray to the battery.... was it a new starter or second hand ??? Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 brand new starter. il check the earth cable when the snow stops! do you think putting jump leads from my engine onto my van would help? getting desperate now!! Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 worth a try mate mite just be a flat battery Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 tried the jump leads. tried putting a lead from the engine to the chassis. it works from a push start. im going to be bald if this carries on!!!!!!!!!!! Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 try knockin the top of the starer with a hammer mite be jammed ... check starter relay Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 where is the starter relay? Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 in the fuse bored in the drivers foot well behind the cover with two green squares ..... but cant remember which one it is.... when u trun the ket to crank feel them and feel if u can feel any clicking Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 it clicks. tried battering the starter aswell. still nothing. do you think it could be the starter? Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 so ur gettin battery voltage at the starter on the big cable, also getting battery voltage to the smaller wire when cranking and the earth is good yeah ?? not an auto is it ??and it didnt help jumpin from another car no ?? Link to post Share on other sites
sanchez 0 Posted November 9, 2008 Author Report Share Posted November 9, 2008 voltage at both. haven't checked the earth yet. too cold! had a lead from the engine to the chassis and then to the battery negative. still nothing!!!! gave the car a push start and everything seems ok when running. Link to post Share on other sites
cabrioman 6 Posted November 9, 2008 Report Share Posted November 9, 2008 check the earth lead when it gets warmer then mate Link to post Share on other sites
sanchez 0 Posted November 10, 2008 Author Report Share Posted November 10, 2008 checked earth leads and there all sound.next step will be taking the starter out i think and throwing it back at vw!!!!!!!! Link to post Share on other sites
cabrioman 6 Posted November 10, 2008 Report Share Posted November 10, 2008 take it off and test it first mate ... did vw fitt it or did u ??? Link to post Share on other sites
sanchez 0 Posted November 10, 2008 Author Report Share Posted November 10, 2008 i fitted it. not paying some apprentice to do an easy job! maybe thats my downfall!! my car overheated last week spilled water on the fan control unit and fecked that. connected???? how do you test the starter when its off? gettin sick of pushing the car to go anywhere. neighbours must be laughing at me, im always tinkering with it!!!!! Link to post Share on other sites
cabrioman 6 Posted November 10, 2008 Report Share Posted November 10, 2008 take it off ... put some jump leads from the battery to the main postive conection and the earth then get a small wire and go from the main postive to the signal conection and see if it engages the starter and spins ... best to put it in a vice and watch ur fingers if it does nothin its buggered if it works theres a prob with the car mate Link to post Share on other sites
cabrioman 6 Posted November 11, 2008 Report Share Posted November 11, 2008 any luck yet fella ??? Link to post Share on other sites
sanchez 0 Posted November 11, 2008 Author Report Share Posted November 11, 2008 too wet for that carry on. decided to down a few cold ones instead! much more appealling have you ever heard of a starter failing? my mate works at a garage and they've never heard of it. Link to post Share on other sites
Dave Lea 4 Posted November 11, 2008 Report Share Posted November 11, 2008 have u power probed the starter to make sure it aint the ign switch Link to post Share on other sites
cabrioman 6 Posted November 11, 2008 Report Share Posted November 11, 2008 i fitted 4 starters to a car once cos they had a bad batch of them Link to post Share on other sites
Dave Lea 4 Posted November 11, 2008 Report Share Posted November 11, 2008 this happens a lot i havefound never rule out a dogey starter Link to post Share on other sites
