Climbatize 0 Posted November 17, 2008 Report Share Posted November 17, 2008 Ive had this prob for quite some time, water is leaking for the exspansion hole on the side, the water pump is fine the thermostat is new, im almost having to fill the tank up every day now :/ no water in the oil, the water is very rusty colour even with the daily top ups its still very rusty water, the aux pump is making a terrible sound so ive got a replacement and will fit in the next few days. Just wondered if anyone has had the same prob and found a solution?Cheers Link to post Share on other sites
DMARK 0 Posted November 17, 2008 Report Share Posted November 17, 2008 Sounds like the pressure relief valve has gone in the cap, cheap as chips from GSF Link to post Share on other sites
Climbatize 0 Posted November 17, 2008 Author Report Share Posted November 17, 2008 been replaced when had thermo done.. Link to post Share on other sites
ingham 5 Posted November 17, 2008 Report Share Posted November 17, 2008 check the small pipe from crack pipe to oil cooler when warm Link to post Share on other sites
Climbatize 0 Posted November 18, 2008 Author Report Share Posted November 18, 2008 dont think i have an oil cooler, looked this morning cant see one. Link to post Share on other sites
spudvr6 0 Posted November 18, 2008 Report Share Posted November 18, 2008 Your oil cooler looks like another filter housing on the front of the block. There is 2 hoses on top.Hope this helps. Link to post Share on other sites
Climbatize 0 Posted November 19, 2008 Author Report Share Posted November 19, 2008 oki found the cooler >.< now what am i checking for ?? from what ive touched 1 pipe seems to be hotter then the other but only checked when i got home 20 mile run, how should them pipes be, both hot or one cold one hot ? soz for my stupidty :/ Link to post Share on other sites
