ive noticed that my steering has started to feel a bit wooly recently , seems mnore vague and suffering with what seems to torque steer . ive changed both the bushes in the wishbone with powerflex items , recent ball joints also,
what could be causing this ??
Proberly not the same as you problem,but recentaly when i changed my gear box when i tightened the bottom of the shocks back up to the hub it was in the wrong place giving me loads of postive camber and made the thing handle very badly indeed.
It would spin up real easy and drag me all over the road with torque steer,and pull me towards the hedge if i hit a bump at speed!
Loosened the bolts on the bottom of the shock and pushed the top off the hub/disc in as far as it would go to give the car some negative camber and it sorted it out a treat.
If you have loosened or had you shocks off i would try that first.
Or maybe its you track rod ends?
