Just started running lumpy...UPDATE - Found oil on the plgs and leads...
Was fine when i came to work - just nipped out and it feels like it's running on 5 cylinders - very lumpy when i rev - although it ticks over at a constant rpm and doesnt feel too bad at higher speeds..
Any suggestions where to start?
Plugs are Magnecor with about 5k on them so that should rule them out.
Thanks for your help
Chris
Bit of an update..thelumpyness is actually a miss..
Checked all the plugs/leads today and 3 of them had oil on them :-\, so i cleaned them and the leads up and went for a spin. Still missing but not as bad as it was.
So what causes oil on the plugs? hopefully me cleaning them has sorted that?
Does it sound like it could be the Coil Pack? or should i stick to finding out why the plugs were covered in oil? I'm kinda stuck for ideas now.
Thanks
Chris
did you change your maf? Or at least unplug your old one? Make sure its the right way round
How old are your spark plugs? Change them if there old..
If you disconnect one lead at a time while its running can you hear a difference... If you pull a lead and engine noise doesn't change then thats where your porblem is... In which case try swapping said lead to see if there an improvment
Altho leads are new you could be unlucky enuff to have a faulty one plus some people pull the lead it selft when removing them which can cause damage
/\ Done all that thanks - turns out i had a mixture of dodgy leads and plugs, swapped em yesterday and the car is now running sweet again :-p Although 2 of the leads popped off today and i thought i was back to square one again,fortunately i wasnt..pheww...
Even so that means my original plugs and leads only lasted about 10k!
Thanks for the help
Chris
