mk3_mason 0 Posted January 3, 2009 Report Share Posted January 3, 2009 I'm converting my estate to a vr6 and only just realized that the clutch on the vr is hydraulic and on the estate is cable !! Can anyone inform me of the part I will need to complete the conversion ??? And how I would go about doing it ! Thank you very much xxxzx Link to post Share on other sites
Kelster 0 Posted January 3, 2009 Report Share Posted January 3, 2009 Hi Mason, would phone you but haven't got your number. I have been doing some research and you can buy a kit for £89.00 from TSR PERFORMANCE. I am sure there are other places that sell them but have been unable to find them. I would almost guarentee Stealth would be able to help too. Link to post Share on other sites
UnitedMotorsport 55 Posted January 3, 2009 Report Share Posted January 3, 2009 Pull the bungs out of the bukhead and fit the master cylinder. Link to post Share on other sites
mk3_mason 0 Posted January 3, 2009 Author Report Share Posted January 3, 2009 I'm new to the vr tho so I have no idea where abouts I need to pull bumga from and what bits I will need to do the whole thing !!!!! Cheers for the info grant !!! I'm just talking to guy from stealth about the immobiliser chip for my ecu so I'll ask about clutch too :-) Link to post Share on other sites
cabrioman 6 Posted January 3, 2009 Report Share Posted January 3, 2009 ill try and get u a pic up tomo mate as i had to do this on my cab ... but like Mr C2 said remove the rubber grommet from the bulk head and run the pipe up to the brake resivor ... ull need a mater cylinder pedal end, slave cylinder gear box end and pipe between the pair .. Link to post Share on other sites
mk3_mason 0 Posted January 3, 2009 Author Report Share Posted January 3, 2009 I have the slave cylinder at the box end just would like a picture of the pedal end if possible !!! Master cylinder and which grommets I need to pop out :-) thank you for the replies :-) Link to post Share on other sites
cabrioman 6 Posted January 3, 2009 Report Share Posted January 3, 2009 red circled area is where the grommet/plate need to be removed from and master cylinder fitted .... Link to post Share on other sites
mk3_mason 0 Posted January 3, 2009 Author Report Share Posted January 3, 2009 legend !! does it run off the brake resevior ???? Link to post Share on other sites
cabrioman 6 Posted January 3, 2009 Report Share Posted January 3, 2009 yeah ull have a small plastic tube coming off it with a sealed end cut the end off and push the pipe on ... its the black and white hose comin out the top of the red circle Link to post Share on other sites
mk3_mason 0 Posted January 4, 2009 Author Report Share Posted January 4, 2009 that's a massive help !!!! Thank you very much :/) Link to post Share on other sites
