Best parts place for 1997 VR6 Highline rear ABS sensor
sorry to intrude and hijack the thread but I have the exact same issue (defined by VAG COM scan) where exactly is the connector for the ABS do i just lift the rear seat up?
I am going to look in the next couple of days Im guesing under the rear seat is where I will look first.
My sensor broke off stuck in the back of the disc cover so I am going to have to remove the disc/caliper to get to it when I have some time of work so watch what you are doing with yours.
Do you have to get a new sensor and if so where are you getting it from.
Hi
Im going to get mine from GSF near heathrow airport same price as the cheaper one you mentioned apparently the later models use the generic ones which is good for us! Mine is 1997 highline too :)
the problem with replacing these is that you have to take off the caliper brake disc ect so looks like I might as well spend some time and change my rear brakes too!
