spiffo 0 Posted January 16, 2009 Report Share Posted January 16, 2009 Hi guys, everytime I press the clutch pedal down there's a loud creaky / squeaky noise as I do it. I thought at first it was the pedal mechanism but having throughly lubricated it, it made no difference. And now I've decided that the noise is louder in the engine bay, I'm beginning to think that the noise is coming from the Slave Cylinder, is that possible ? Link to post Share on other sites
Moochalargo 0 Posted January 17, 2009 Report Share Posted January 17, 2009 Id like to know this one aswell as ine used to do this! Link to post Share on other sites
spiffo 0 Posted January 17, 2009 Author Report Share Posted January 17, 2009 What makes me think it's the slave cylinder is that the noise appears to come from all over the engine bay, i.e. it's difficult to pin it down to a specific area.This is what makes me think it's the slave cylinder because it's bolted to the bulkhead so it would make the whole bulkhead resonate if the piston inside the cylinder was rubbing as you depress the pedal.That's my theory anyway ;-) Link to post Share on other sites
Bigjobbo 0 Posted January 17, 2009 Report Share Posted January 17, 2009 Just to clarify, before you order parts, the one on the bulkhead is the master, and the one on the box is the slave. Any clutch slip? Link to post Share on other sites
spiffo 0 Posted January 18, 2009 Author Report Share Posted January 18, 2009 Absolutely Correct, it's the Master Cylinder that's bolted to the bulkhead, just checked on ETKA, 1H2 721 401, I think.No clutch slip, Bigjobbo, why do you ask ? Link to post Share on other sites
darkstepper 0 Posted January 26, 2009 Report Share Posted January 26, 2009 I just changed my clutch because I had the same noise! I thought it was the thrust bearing because i checked the slave cylinder and it was working....after replacing the clutch the noise persisted it turned out to b the clutch fork!!! Link to post Share on other sites
stuey 0 Posted March 28, 2009 Report Share Posted March 28, 2009 My car is doing this, there was a thread about it a while ago. I believe it is something to do with a bushing, possibly could be the fork. The thread said it needs a different lube?? Sounds like a box off job unfortunately... Link to post Share on other sites
stuey 0 Posted April 3, 2009 Report Share Posted April 3, 2009 I spoke to Vince at Stealth, he said he has had loads of problems with VR6 clutches. He thinks there are a couple of makes that are causing the problem, but the makers don't want to know. It might be a new clutch and fork that will be the cure, he said it shouldnt cause any problems if left alone (apart from being annoying!!) Link to post Share on other sites
