rattly first gear on pull away and stop
Mine started to rattle a little in first an when slowing down.....then the whine started...about a week later it went bang and the gears and part of the bell housing bust out on da road..NIGHTMARE ..took me 6 weeks to get a decent gearbox from England (to Ireland )an fitted..Get it looked at before its too late.
The boxes are repairable if you catch them in time. The casing expands around the diff bearing (whine or rumble) and the bearings shoot out and blow a hole in the casing (bang). I repaired mine for 80 notes, when it was rumbling it's nuts off in every gear. Try the oil change first as cabrioman mentioned.
