vento-rob 0 Posted January 26, 2009 Report Share Posted January 26, 2009 Ello folks.I have a few issues with the car which i need some help with as the vr6 engine is fairly new to me.The car coughs and splutters intermittantly, i read that a change of plugs and leads can some time cure this, but not in my case.This morning the car was bad so got to work and changed the plugs and leads. it seems better but the problem is now more intermittant.the only way i can describe it as it like the car is holding back and fighting (not all the time though) then whooooshh of she goes.Any ideas? when i got the car was told it has a faulty maf sensor, could this be the underlying issue?Cheers Folks answers in the usual fashion lolRob Link to post Share on other sites
ip 0 Posted January 27, 2009 Report Share Posted January 27, 2009 Yes, a faulty MAF will do this. Worth getting a VAG-COM reading done (someone in the club should be able o help), it could also be the temp sensor but a reading will show this up.ip Link to post Share on other sites
vento-rob 0 Posted February 1, 2009 Author Report Share Posted February 1, 2009 right so far i have changed temp sensor new maf meter plugs and leads the car ran fien for about 3 days and now i have a few other issuesshe is really overfulling and stalls every time i dump the clutch approching a junction etc, any ideas what this could eb.please peeps this is really beggining to do my noodle in.ThanksRob Link to post Share on other sites
t111bul 0 Posted February 2, 2009 Report Share Posted February 2, 2009 Does the car run ok when it's cold? Link to post Share on other sites
vento-rob 0 Posted February 4, 2009 Author Report Share Posted February 4, 2009 yes it does starts and ticks over fine and drives fairy nice Link to post Share on other sites
jellsta 0 Posted February 11, 2009 Report Share Posted February 11, 2009 what temp sensor did u replace was it the coolant one?? as mines running like yours and have changed plugs leads and MAF. VAG com comes up with coolant temp sensor intermitant. could this make the engine run lumpy?? Link to post Share on other sites
