jambojones10 0 Posted October 26, 2004 Report Share Posted October 26, 2004 Just installed new stereo. Works fine but evertime you turn the ignition off it loses the stored stations. Does this meen i've got one of the wires wrong? Link to post Share on other sites
danb 0 Posted October 26, 2004 Report Share Posted October 26, 2004 you need a permanant live to the stereo so it saves all the radio stations and all of your settings . Did the stereo loom bstill have the original plugs on them , if not and you cant find a wire you can run one straight from the battery . Does ciggy lighter not have a permanant feed ? Link to post Share on other sites
binliner 0 Posted October 26, 2004 Report Share Posted October 26, 2004 My pioneer did the same... the constant live (yellow) and ignition live (red) were different colours in different vehicles apparently... swapping those round (connecting red to yellow and vice versa) solved it Link to post Share on other sites
SankysVR6 1 Posted October 26, 2004 Report Share Posted October 26, 2004 or you could just get a voltmeter on it and see which ones 12v all the time.or failing that get 12V bulb attach 2 wires to it put one end ground and the other end to either end of the two wires and see which one lights up the bulb with the key out Link to post Share on other sites
madspark01 0 Posted November 8, 2004 Report Share Posted November 8, 2004 if it is an ISO connector at the rear danb is spot on swap over the red and yellow if it is anew good quality hi fi there will be bullit connections to allow you to do this without cutting any wires Link to post Share on other sites
luckstar69 0 Posted February 20, 2009 Report Share Posted February 20, 2009 This is an old thread but without it I would not have been able to fix my own stereo problem, THANK YOU!!! Link to post Share on other sites
