are the fans on the vr6 controlled by the ECU? if so we had a right game trying to sort that out on diagnostics on a fiesta controlled by ECU.
If even unplugged it spins, must mean it's got power from somewhere it's not meant to.. Maybe a relay has stuck open or something so it's just powering up constantly..
The only way of fault finding it (short of swapping it with another known good unit) is to get a multimeter on the sensor connections using the wiring diagrams (available on 'net) as reference.
You've tried a few obvious things and have a good idea what to investigate so hop to it. Sadly, as far as I'm aware, there aren't any vr6oc members who are both psychic and proficient in telekinesis so it looks like you're going to have to do it the hard way! :P
It's all on page 3 & 4 of the wiring diagrams pdf that you should be able to find... not going to post it as I'm unsure of legality of it!
You've proved it's not the sensors fault by unplugging it. Now you need to prove it's not a wiring short with your multimeter. If it isn't then it's the unit itself.
