DasAutoVR6 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Which of the 2 below if any is it possible to fit to my vr6 and what adapters etc are needed. Which size will also look best?1) 8x17 et40 5x1202) 7x16 et24 5x112Thanks Link to post Share on other sites
amazak 3 Posted February 7, 2009 Report Share Posted February 7, 2009 The ET is bit too low, your adapters are minimum 15mm so the ET ideally needs to be around 50, Adapters for 5x100 to 5x112 are easy to get. EG. wheels with 50 after 15mm hub adapters they would come down to 35 which is vr fitment, now I beleive you could get away with lower ET's but archwork may be required as they would stick out a bit, basically the lower the ET the more wheels poke out the arches.Someone correct me if I am wrong.Cheers Link to post Share on other sites
craggsy 91 Posted February 7, 2009 Report Share Posted February 7, 2009 The ET is bit too low' date=' your adapters are minimum 15mm so the ET ideally needs to be around 50, Adapters for 5x100 to 5x112 are easy to get. EG. wheels with 50 after 15mm hub adapters they would come down to 35 which is vr fitment, now I beleive you could get away with lower ET's but archwork may be required as they would stick out a bit, basically the lower the ET the more wheels poke out the arches.Someone correct me if I am wrong.Cheers[/quote']Thats basicly it matey Link to post Share on other sites
amazak 3 Posted February 7, 2009 Report Share Posted February 7, 2009 Thats basicly it mateyThanks Craig, I knew I was writing some sence. 8-) Link to post Share on other sites
DasAutoVR6 0 Posted February 8, 2009 Author Report Share Posted February 8, 2009 Thanks! So 7.25x17 wheels 5x112 with et54 would be almost perfect with 15mm adapters?? Link to post Share on other sites
