Wheel Advice Help Needed Or Have I Been Cheated.
I bought some second hand Keskin KT1s in good condition rears are 5 x 100, ET 15, 16 x 9 and fit perfectly with loads of arch rubbing LOL. but i will be getting the arches done by archenemy on the 22nd of February.
Now my problem with the fronts, they say they are 5 x 100, ET 35, 16 x 7.5, and guess what they wont fit and dont clear the caliper. I am sure this is the right offset, but judging by the back of the wheel its a bit flush to be 35.
can anyone help, i have been told i have the wrong brake discs, calipers etc, i have swapped and changed and even bought the same discs twice and still no joy with the rims, the last thing i now have to do is purchase some spacers whihc i was trying to avoid.
Does anyone know the correct part numbers for the following.
Brake discs/pads for a VR6 M Reg 1994, AAA122672?
The Correct Offset?
And is it possible to stamp a wheel with a ET35 and cover up the original size?
Thanks in advance.
Pat
Thanks Cabrio.
Well i have one thing right then i have 280mm disc. bt last time i tried a spacer i ended up with the result below which i was told was illegal. I was just assuming that because the rim was ET35 i would not need a spacer and it would be a straight fit. But i dont mind spacers at all as long as they dont look like this LOL
