MK2 - R32 Conversion Help
Hi guys am thinking about doing the above conversion and will hopefully have a full donor R32 car (probably a MK4). Does anyone have any guides or advice. I know i can use the VR6 crossmember and VR6 mounts, the 6 speedbox needs to be made to a 2wd. What about wiring etc. Ideally am hoping to transfer everything over from the R32 including dash, clocks, a/c, abs etc.
Thanks for any advice, tips in advance.
I know it would be easier to use the vr6 gearbox/flywheel and clutch but i want the 6 speed box. I already have a MK2 VR6 which i will sell' date=' i dont see the point in just dropping the engine in i would rather to the full converation as i will have a donor car.
Fair play i like the way your thinking. I think at this point you should just fuck it and go 4 wheel drive
