redtops and 4" maf
right, got both installed now. what i would like to know is, what fuel pressure are you guys using..
ive got my rrfpr , set a 3.5 bar.. and it seems to be working ok.. i realise that it aint gonna be perfect . but it should surfice until end of next month when i can get a chip from c2.
im gonna stick it on vagcom later and see whats doing what, with a little logging..
also i seem to get sometimes a little bogging, which ive put down to excess fuel before the cams and turbo kick in.
cheers jim
  • 1 month later...
Erm, no, you drop the 440s in (@ 3 bar) with a 4" MAF and the stock software will adapt automatically. Is it OBD2 you've got? I've done that myself with OBD2 and it drives OK. Not brilliant, but it'll get you to your remapper.
You only need the BEGI and MAF clamp if you're planning on using the stock fuel injectors, stock software, stock MAF and a high pressure fuel pump.
I've done that aswell and it worked bloody well :-)
Probably my favourite method actually, but it was my first attempt and after a standard VR6, it was crazy fast.
