kcw 1 Posted February 19, 2009 Report Share Posted February 19, 2009 I've bought a 2nd engine to prep for turboing but its got a hole in the bottom end, also have a spare block with it though so can combine to 2 to get a nice fresh vr for turbotime. What I wanna know if what parts should I be replacing when the block is stripped down? Whats essential, whats ptional etc.Thanks in advanceKen Link to post Share on other sites
LadVR 0 Posted February 19, 2009 Report Share Posted February 19, 2009 if its in bits then i would change every wearing surface ie, bearings, guides, chains, + seals and gaskets, oil pump etc. might as well do it all at once whilst its stripped. Link to post Share on other sites
mike 6 Posted February 19, 2009 Report Share Posted February 19, 2009 if its in bits then i would change every wearing surface ie' date=' bearings, guides, chains, + seals and gaskets, oil pump etc. might as well do it all at once whilst its stripped.[/quote']not seen you post in ages mate, you still goto lichfield meets? Link to post Share on other sites
LadVR 0 Posted February 26, 2009 Report Share Posted February 26, 2009 if its in bits then i would change every wearing surface ie' date=' bearings, guides, chains, + seals and gaskets, oil pump etc. might as well do it all at once whilst its stripped.[/quote']not seen you post in ages mate, you still goto lichfield meets?yeah we still go mate, although there isnt much vw stuff about at the mo, everyone has a project in bits! Link to post Share on other sites
kcw 1 Posted February 27, 2009 Author Report Share Posted February 27, 2009 Sorry forgot I'd posted this, how much do you recon it'll cost for all the parts for rebulding the bottom end?Already have new valve stem oil seals just incase.Ken Link to post Share on other sites
Phat VR6 3 Posted February 27, 2009 Report Share Posted February 27, 2009 if its in bits then i would change every wearing surface ie' date=' bearings, guides, chains, + seals and gaskets, oil pump etc. might as well do it all at once whilst its stripped.[/quote']not seen you post in ages mate, you still goto lichfield meets?yeah we still go mate, although there isnt much vw stuff about at the mo, everyone has a project in bits!where do you go up lichfield? Link to post Share on other sites
Phat VR6 3 Posted February 27, 2009 Report Share Posted February 27, 2009 Sorry forgot I'd posted this' date=' how much do you recon it'll cost for all the parts for rebulding the bottom end?Already have new valve stem oil seals just incase.Ken[/quote']around 400-£500 depending on how far you go Link to post Share on other sites
