pat_986 0 Posted March 2, 2009 Report Share Posted March 2, 2009 HiThink my VR is over pressurizing, the top hose is rock hard, and a leak appers from the stat housing(?) above the GBox?Do you know what could cause this?Cheers Pat Link to post Share on other sites
SankysVR6 1 Posted March 2, 2009 Report Share Posted March 2, 2009 A picture might help, of the leak. Link to post Share on other sites
pat_986 0 Posted March 2, 2009 Author Report Share Posted March 2, 2009 Cheers, will get one soon.I think its the stat housing, just below the coil/distributor on the RH of the engine. Link to post Share on other sites
mpgscott 0 Posted March 2, 2009 Report Share Posted March 2, 2009 Faulty water pump! Link to post Share on other sites
pat_986 0 Posted March 3, 2009 Author Report Share Posted March 3, 2009 No, don't say that!Is it a big job, chains need to come off?? Link to post Share on other sites
pat_986 0 Posted March 3, 2009 Author Report Share Posted March 3, 2009 Think the pump is working, its circulating up to the header tank Link to post Share on other sites
Timah89 1 Posted March 3, 2009 Report Share Posted March 3, 2009 Think what you are seeing is Aux water pump [electrical]. Real one is on drivers side and original ones are notorious for loosing plastic vanes and bearings going ending up with your car sounding like a tank! Replace pump, belt and tensioner in c2hrs and £100 from GSF. I put post up a while ago on how to do thisCheers Link to post Share on other sites
pat_986 0 Posted March 3, 2009 Author Report Share Posted March 3, 2009 Cheers.just so I know where I am, why would the cooling system become pressuised if the water pump had gone? Link to post Share on other sites
thegoth 5 Posted March 3, 2009 Report Share Posted March 3, 2009 it should always presurize to some degree as the coolant expands when hot. But you should be able to just about squeeze the pipes out of shape. what is the temp gauge on the dash reading? Link to post Share on other sites
pat_986 0 Posted March 3, 2009 Author Report Share Posted March 3, 2009 Normal TempsLike I say, the top hose was rock, with exesive pressure relesed when i opened the expantion tank? Link to post Share on other sites
