RFC84 0 Posted March 13, 2009 Report Share Posted March 13, 2009 Got my kit from ebay and was gonna try fit it todayhttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=190288376544Ive found these guides, just wondering if theres anything that it has missed or if theres any other guides that would be helpful? Cheers http://www.corrado-club.com/faq/detail_faq.CFM?FAQID=179http://www.gti-vr6.net/library/engine/repl_VR6_therm_housing.html#mark3 Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 think they cover it all. If you are careful taking the housing off you should be able to keep your new crack pipe for future use. Link to post Share on other sites
Ed 2 Posted March 13, 2009 Report Share Posted March 13, 2009 YOu saved me starting another new thread! I have to purchased the same kit an will be fitting mine tonight and or Saturday morning! Looks like an easy ish job! Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 can be ;-) only three bolts but they can get corroded and sieze. The housing has metal sleeves which on mine (1992) had completely rusted to the washers and bolts so I had to drill them out. A good dose of WD40 or even better plusgas will help. Link to post Share on other sites
RFC84 0 Posted March 13, 2009 Author Report Share Posted March 13, 2009 YOu saved me starting another new thread! I have to purchased the same kit an will be fitting mine tonight and or Saturday morning! Looks like an easy ish job!We'll both be on here at some point tomorrow when we get stuck then! lol :-p Link to post Share on other sites
RFC84 0 Posted March 13, 2009 Author Report Share Posted March 13, 2009 Thanks Goth...did you mention the other day to re-join the pipes with jubilee clips?? Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 yes, you are likely to shag the existing spring clips whilst getting them off unless you have the proper tool Link to post Share on other sites
pat_986 0 Posted March 13, 2009 Report Share Posted March 13, 2009 Just got the last kit!Anyone going to do the water pump at the same time? Just thinking the VW G12 (or whatever it is called) is bond to be £20odd, so wondering if it a false economy not to do the pump, while doing the rest??? Link to post Share on other sites
VR6Pete 1,455 Posted March 13, 2009 Report Share Posted March 13, 2009 They dont call it a crack pipe for nothing just be carful, I know loads of people who've cracked the crack pipe Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 the kits come with one. which is good it's jut a bit of a pain to do as the access isn't great to undo the the connection to oil cooler.as for the water pump that is a far greater job as it won't come out without undoing the engine mounts and jacking the engine up. so really depneds on your comitment and level of skill Link to post Share on other sites
pat_986 0 Posted March 13, 2009 Report Share Posted March 13, 2009 Well, i'm capable of doing the work, just wondering if its one of things that people do while they are there?think I will leave it as I think the pump is good, and shouldn't be much greif to change later if needed.Thanks Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 if I know the coolant is relativly fresh I have no problems with reusing it assuming I can catch it ;-) Link to post Share on other sites
pat_986 0 Posted March 13, 2009 Report Share Posted March 13, 2009 Yeah, think I would do the same.Why is it so importnat to use this G12 stuff? Sorry first VW! Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 As well as antifreeze it has a corrosion prohibitor. the original G12 wasn't compatible with the earler G11 formula. so if you wanted to change you needed do have a damn good flush.VW then released the plus version which could be mixed.these days it's G12++ not sure what the second plus signifies. Link to post Share on other sites
pat_986 0 Posted March 13, 2009 Report Share Posted March 13, 2009 Cool, thanks for that! Link to post Share on other sites
russvr6 0 Posted March 13, 2009 Report Share Posted March 13, 2009 just like to say i had mine changed today cost £100 including parts and labour Link to post Share on other sites
Ed 2 Posted March 13, 2009 Report Share Posted March 13, 2009 I read some were that some people dont put the stat back in when replacing? is this true? Link to post Share on other sites
thegoth 5 Posted March 13, 2009 Report Share Posted March 13, 2009 I've certainly heard of people running without them temporarily, or with then knowingly stuck open ;-) But it's best to have one, helps get the engine up to running temp quicker. Reducing fuel consumption and wear. Using a low temp one is a common choice. Link to post Share on other sites
Ed 2 Posted March 13, 2009 Report Share Posted March 13, 2009 was tempted to get one from awesome but as i have one sitting in the garage i might as well use that! ill think ill do the job with the stat in! Link to post Share on other sites
