Hi Guys
Jumped into my car last night nd the temperture light was flashin on the dash...i looked under the bonnet and can see water dripping from the bottom of the car , wen i looked through each of the pipes i squeezed the main pipe and this is one goin into the side of the engine and i can see water sprayin around through a small gap ...any body got any idea wat could be wrong, all the pipes seems to be fine.
can you put up a picture of where it's coming from mate ? but if it's from the plastic bits attached to the engine just below and to the left of the coilpack as you look at it then it's coming from the thermostat housing - a common problem and luckily an easy and cheap fix :)
